My 1450 has the hydraulic lift, the problem is the lift arms on the rock shaft are held in place by roll pins. 2 years ago I broke the original roll pin and lost my lift. After psending hours I was finally able to drive the remains of the pin out.
I replaced the roll pin with what I could find and all was good for about one mowing season - the new pin apparently wasn't big enough and it slipped out. I spent some time and found the correct size roll pin. And installed it last winter. It worked through the summer but I managed to break it yesterday while pushing snow - the lift arm was taking a beating from the gravel and transmitted te shock to rock shaft.
Where do you get a GOOD/correct roll pin and what have others used on the rock shaft?
http://www.partstree.com/parts/?lc=cub_cadet&mn=1450&dn=0024800031
What I keep breaking is the roll pin that connects part 3 and part 1.
