Allis chalmers snow blower
PaulD
Can anyone tell me if a snow blower off of a b212 allis tractor will fit on a 918 allis tractor? If it won't fit which snow blower will fit? If anyone has pi tures of the right snow blower for a 918 that would be a huge help to. Thanks in advance.
Hit should fit right on there, only thing that could be different is how it goes on front axle back to deck mounts where pins go in, minor modification will make it work, also a 918 might be wider than 36"? If you have a 36" blower might wanna find a 42" because I could use a 42" on my allis 410 because my tires on outside are 37-1/2" and in deep snow the tires hitting that little bit can hang you up easy when backing up that first pass. I wish this one was mine, someone took time and made a two stage work on a allis. And put on some meaty tires would be a nice unit
