looking for Bolens hydraulic lift
Your best bet is to keep any eye out on eBay, as they show up there from time to time.
They usually sell in the $200-$300 range.
Also, be aware that if you have a G10 or G11 with the Briggs engine, you will have to make a set of mounting bars for it as the 'standard' ones will not work as the holes are too small and they aren't wide enough to drill the larger holes in them.
I'm not sure if that applies to the Tec powered tube frames.
If yours has the Wisconsin, then they work with no problem.
Thank you for the reply, I appreciate the info.
Yes, I will keep an eye out on ebay. My 850 tube frame has the Wisconsin, so sounds like the main thing is finding the hydraulic kit :)
Thanks again!
