snapper Z rider turf cruiser ZF2200k
I have one of these mowers and the left side quit moving, is there any tricks I can try to get it moving again or can this transaxle be rebuilt or is there any available. I dont know anything about these transaxles
thanks
Not familiar with that model, but hope it has Hydrogear transaxles in it. If its Eaton, your luck in finding a transaxle or parts drops significantly.
First, does it have enough oil in it?
if it hydro gear unit yea you can rebuild.parts are easy to get thru hydro gear dealer.you do have the neutral lever in correct position don't you.i can get you parts. does it go at all when cold,or does it go south when it gets warm.check the pulley on top it is turning the shaft isn't it. could have sheared key.
