Indiana Ken
I have a 1970 Horse 1, S/N 14673 that needs new bearings on the drive shaft. The shaft (approximately 24" long) runs the full length of the tiller and drives the front gearbox for the wheels and the rear tiller tines. It uses two tapered roller bearings, one at each end. Shims are used to set the end play or preload the tapered bearings.
My question is: What is the specification for the bearings? Do I shim for a slight amount of end play or are they preloaded by a few thousands?
I have found owner manuals and parts manuals on line - but no specs. Thanks for any replys.
