njdaveskiing
I have a Tecumseh snowking 5hp snowblower engine with non-adj. carb. It will start and run 30 seconds then die, after a couple minutes start again and run 30 seconds or more then die again, then start and keep running. It will not idle and runs rich. I have replaced w/new carb.,checked fuel tank and line, has good spark, replaced coil last yr. It did the same w/ the old carb.(old carb is good) Drilled hole in cap. Changed governor setting but doesn't seem to matter.
My thought is some kind of valve problem since it will run once warmed up but doesn't seem to have a lot of power.
Anybody have a good answer ?[color=darkred:8486f98ed0][/color:8486f98ed0][color=blue:8486f98ed0][/color:8486f98ed0][color=darkblue:8486f98ed0][/color:8486f98ed0] :?:
