Tom Arnold: added nother Ingy to the garage
4435
248 hrs 60inch deck. Doesn't charge and starter sounds draggy. Runs a little rough just got it home today. Hope I can find enough parts to keep it going. Tom
Those are very low hours but the appearance certainly supports
what the hour meter is saying. Nice score. In truth, what you
have is actually a Grazer ZTR with Ingersoll badging and Power
Red paint.
Ingersoll bought the Grazer Division in order to add ZTR's to
their lineup and continued to offer the Grazer models to the
existing Grazer dealer network while selling the ones marked
Ingersoll to their dealers. Today, these models are slightly dated
in the world of ZTR's but those who own them say that they are
a joy to operate and still hold their own when cutting grass at a
high ground speed.
Parts should not be a problem. Use the link below. Brian will
provide you with whatever you need. After you get some seat
time late next spring, let me know what your impression is.
Salem Power
It looks a lot like my Deines ZTR's. You will love the
independent deck out front. The John Deere Z Trac machines
have the mower mounted rigid and they don't follow the
contours of the yard well.
Like Tom says - you can mow at full speed. With a single rear
wheel it isn't as rough either. You never hit the same bumps
twice. If you ever get stuck just raise the deck and it will add
enough weight to drive out. Keep fluid in the gearbox on the
mower unit that the belts go to. They aren't cheap to replace.
The lower seal went out on both of mine so I put a zerk in it
and give it a couple of pumps of grease each time I mow.
