Brendon-KS
- Location
- Goessel, KS
I am planning to build a Cat 0 hitch frame to complete a "it's all there except than that" Brinly plow that I have but I have a question about the design. Virtually all the pictures I have seen of these plows shows the square cross tube positioned above both pin holes on the right side and between the holes on the left. However, I have found a few pictures of factory-looking frames that have the tube between the holes on the right and below both holes on the left. In the parts catalog there are two part numbers for the frame, one for the PP-1200 and one for the PP-1210 but only the "typical" frame is pictured. Is the frame with the tube lower in relation to the hitch the 1210 version? I didn't come up with much when I googled "Brinly PP-1210". I will be using this plow on a Power King 2418 with the hitch positioned quite a bit higher than a typical garden tractor so the "non-typical" frame is appealing to me. But, I also want to have a plow that is an accurate copy of the original. Can anybody shed some light on the two frame versions? Thanks.
