K 181 fuel pump
For those who are unhappy with the mechanical fuel pumps, there are low pressure electric fuel pumps available. Some are even adjustable. Just connect the ground wire to the frame of the tractor and the hot lead to the plus side of the ignition coil. The pump runs only when the key is in the ON position.
There are also pulse pumps that work off the oscillating pressures found in the crankcase.
Thanks for the input guys. Got my pump kit off ebay for under 40 bucks. Same kit from parts house was over 50 and a whole pump was 120. It' s going on a Speedex S18. Mike
