Mike in MI
Tom,
Been a while since I been on Yesterdays tractors I think it was this last May anyways. Not sure if you can remember me or not? I asked what type hydraulic fluid to use in the 646's. You told me 20W/50.
Not going to believe this but since I got on here and asked the question I have gotten real busy since with neighbors wanting me to work on there mowers ect. Don't know why as I did'nt advertize it anyways. Anyways it was enought that it keep me an my freind busy all summer.
I got all power red items parts painted and installed. Since then I decited to leave the industial yellow parts like loader, fenders, Ect go till next spring when it warms back up.
I did get most of it put back together and I been using it off an on now an then.
I got this 646 in a bushel back case so too speak.
Boy what a time I had with the plumbing figureing it out what goes where. Tractor did'nt have a engine in it when I got it. The old engine 16.5 hp was in bad shape. I did'nt know if I could make a P220 engine that I had out of a JD 420 work or not but I gave it a try. Tight fit but I got her to work ok so far. Few alterations but not that many as what I would have had.
I do know one thing it would of been easyer to work on if I was a pigme W/Out Polioasist to get into them tight areas. Some of my new paint job got scratched up already. I need to get some more parts yet like the steering wheel and seat yet. Right now I have a 224 steering wheel on it and it sets too low to the seat for the leg an knee room. Must be the 646 steering wheel much taller? I do need to order some lift Cylinder seals. Both sides are leaking bad. This 646 been setting for 23 years in a guys barn. Didn't want to spend the money for a engine o/h. I figure the orings in the cylinder are dry rotted or cracked over the years. I did find a part # for the seals Old # T41499 New # 28788 Pricey at 78.02 per cylinder.
All an all I was surprized when we started it up as I thought we have a bunch of oil leaks or something not right in the plumming anyways but no leaks in any valved or lines what so ever only the lift cylinders. I rewire a new harness and it work ok when starting it. I did install a low pressure oil gauge and done away with the idiot light for now could'nt find one for it at the time. Onan engine carries 25 lbs oil pressure. I think thats good? I see the new fuel tanks are made of plastic now. The old one had rotted from rain water in it.
One thing for sure I like to figure out how I can install a power steering unit in it. Not much room but I'm going to try anyways. I'm no spring chicken no more!!
Better close this book I wrote sorry about that! .
And thanks for your help on the question I asked back in May! Like to get few pictures taken of it but I keep forgetting my camera.
Take Care Tom I'll try getting on more often since the big rush this summer.
Mike
Mike
