Cub cadet 1200 series throw out bearing.
Does any one have a cross over part # for the Cub Cadet throw out bearing?
The part # is 9413056 so I could pick it up at my local bearing house.
Thanks north east puller
That throwout bearing is actually a bearing pressed inside of a sleeve. If your sleeve is still OK you can press the bearing out of it and replace it with a standard 203KKR2 bearing. You can get these at TSC or bearing house for less than $10. A Link to TSC part is provided here. If the sleeve is shot and you don't have a lathe then you have no choice but to pay the $50 price form Cub Cadet.
TSC bearing for clutch
Thanks Butch for the reply .My sleeve doe not look that good. So I will have to bight the pullet and go oem. I did find a cub web sight that does cub pulling clutches that has the oem bearing for 25 bucks. So that is not too bad. At the moment we are playing phone tag. So I do not have it ordered just yet
North east puller
