While mowing, my JD 425, 94 edition emitted an ugly noise and stopped. Tried to start it but the engine was frozen. Manually rotated the drive shaft and I was able to crank it but no engine start. The flywheel engaged okay but there was zero compression. While it was turning, the front PTO was also turning. Then the engine locked up again.
I guess I am looking to perform some kind of surgery. My first wild guess would be the timing gear, which for this early model is plastic. But then a connecting rod and maybe piston(s) could be very possible candidates. What would be a reasonable approach, take the timing cover off or take the whole engine off and go from there? If possible, I would like to minimize my work.
P.S. As an additional note, when I checked compression I noticed the inner electrode of one spark plug was loose and was touching the plug point. Obviously there was no spark out of the plug. I do not know if the engine running on one cylinder could have caused the mishap.
