notjustair
My ZTR has a 16 horse Kohler Magnum that is getting progressively harder to start when cold. The carb is adjusted well, it has gravity flow with plenty of fuel flow, and the choke is closing all the way. It runs perfectly once you get it started but you literally have to run the battery nearly dead to get it going. I want to replace the plug and then check and make sure I have a hot enough spark. Anyone know what the recommended plug is? It has a Champion of some kind in there that has been in it since I got it but I have lost my faith in champs and will go another route.
If I give it a shot of ether it pops right off, but I don't want to keep doing that!
