case 155 pto
Just asking could anyone tell me where I might find a pto mechanism for a case 155 tractor .It is located on the front of the tractor .Thanks Scott
My suggestion would be to see if you could install the newer style of PTO, known as the EZ Adjust Clutch. Good used EZ Adjust Clutches often appear for sale on e-Bay. You must get one for a Kohler, not an Onan engine.
The OEM clutch for the 155 has been out of production for many years. The question that must be answered here is whether there is enough room between the flywheel and the oil cooler for the newer style clutch. I do not have that information. Perhaps Ken C will chime in here on this issue and he might also have a clutch for you.
Tom, he already has a project going............ an early 1967 195....The clutch disk is stuck to the plate and we are soaking the heck outta it right now to get it broke free
Well............... then it should be easy for him to figure out if the EZ Clutch will have enough room on that 195. Of course, there is also the issue of the linkage. It my have to be changed to a Push/Pull rod such as was used on the 1970/71 models.
