I don't normally remove spring from governor arm but this time I did...I didn't mark it a week ago and can't see any wear on the holes.
Kohler CV14S.
14107
2832309131
The gov arm has three holes. Top is close to govenor shaft, bottom is furthest away.
If I put the spring in top hole, the RPM sounds too low. If I put spring in middle hole, RPM is a little high. I haven't run it with the deck yet. The choke linkage is adjustable once the RPM has been set.
I set the RPM by sound. It could be the 14hp is supposed to be quiet? I might have an old auto tach on a tune-up meter.
Kohler CV14S.
14107
2832309131
