Kohler Command 25
41106
I bought a used Exmark Zero turn that had a blown engine....cracked case. It is the V twin spec#CH730 0127 BA. Question is, I found used engine listed as spec # 68613 model# CH25S....will this fit?? Any help will be appreciated. I usually play with full size tractors so I am new to this. Thank you!
I believe it will fit.
If the crankshaft is same length and diameter, it should work. The bolt mount pattern should be the same.
Do not buy a CH22S for it. They had a crank gear defect.
CH25S is 25 horsepower.
I think CH730 is saying 730cc, aka 25 horsepower.
$2k for an engine! I hope you got the rest of machine for cheap.
Ebay listing
Just realized. The one in the ebay pic has a flywheel cover. You would need to remove that so you can add your drive pump pulley to engine.
If the seller is reputable, they should know for certain if they are interchangeable.
