Charles in Aus.
I have a lawn mower that has the Briggs 675 '' Ready start'' 190cc motor it's fine when it runs but does it take some effort to start !
New plug , air filter , clean fuel and clean carburettor . Good spark ,compression and fuel flow .
It seems to be over choking , plug is always wet when I pull it out .Only way I can start it is to take off the air filter , prop open the choke plate with a screw driver and give it a squirt of ether .
Starts at the second pull then and after replacing the filter runs very well with lots of throttle control and power .
I can start it again easily when hot , but let it cool down and it's the same rigmarole to get it going again .
Any ideas on this one ?
