Briggs engine problem
Binderman
I have an 18.5 Briggs Intek engine on my Swisher pull behind mower. A week ago while I was mowing it started missing and losing power, I pulled the plug and it was white, so it must be running very lean, I put in a new plug, and in about 20 minutes it was missing and back firing so bad I had to shut it down. Any suggestions on my problem, carb, fuel filter?? It isn't losing any oil, thank you for any help on this...........Binderman
I saw a briggs engine over heat, a mouse built a nest over the engine and chewed on the spark plug wire.
