I CHECKED THE PRESSURE ON PUMP AND IT STARTED OUT AROUND 200PSI, BUT THE PRESSURE STARTED DROPPING .IMMEDIATELY,AFTER COMPLETE WARM UP IT STOPPED AT 85PSI.
also CHECKED IMPLEMENT PRESSURE AND COULD ONLY GET 140PSI AT END OF CYLINDER STROKE.
dOES THIS MEAN VALVES BAD OR PUMP NEEDS REBUILT? dOWN LOADED SUNDSTRAND MANUAL AND CLOSET COULD COME UP WITH, IS WARMER OIL GETS WORST SYSTEM GETS, I CAN PUSH TRACTOR WITH UNLOADER VALVE CLOSED
APP. ANY AND ALL HELP EVERYONE CAN GIVE ME
thanks
thanks
