john deere gator will not shut off
1953superm
New User
i have a 4x2 john deere gator that will not shut off when the key is turned off. you can remove the switch from the harness and it still runs anyone have any idea what is wrong?
Generally small engines shut off,by the switch grounding the magneto/coil output,could be bad switch or open(broken)wire from coil to switch.
Probably a defective switch. If it has battery ignition it's not stopping the battery voltage. If you have a mag or electronic ignition you're not getting a ground on your switch to stop the engine. Hal
