No power to solenoid on Allis Chalmers AC23420
48C-MAN
I have a good batt, solenoid and now a new ignition switch due to I thought that was the problem. The fuse is good. When I turn the switch to start I get nothing any ideas? The headlights light the elec. pto pulls, and if I jump to yellow wire on the solenoid the mower starts right up.
Some of those solenoids need to be grounded usually with a foot pedal then the engine will crank allowing battery voltage to the starter or starter/generator. Hal
Is that one of the newer Briggs and Stratton built Allises?
If so, you probably have either a safety switch or a relay not working. I guess you are trying to start it with you in the seat, the clutch pressed down, and the pto off.
