TORO 11-32 front engine mount mower
ktznz
New User
The vertical shaft that is driven by my engine also drives the belt that drives the mower blade. The last time I used it, it died on me after it got hot and I was able to determine that the shaft was locked up. When the engine cooled down, I could start the engine and cut until it reached a certain temperature and locked up again. Any ideas as to what is causing the lockup and what part(s) need replacing?? Thanks.
Thanks, I will try to locate a manual and look at the engine section to see what and where the bearing is located and then try to find the nuber so that it can be replaced. I will look for the manual on this site and then branch out to other locations.
Found the parts catalog for my 11 HP front engine Toro. On page 7 of the manual, I see what appears to be the pulley assembly Do not see any part listed as shaft bearing. I see
spacer - pulley, 27-8910
sheave (do not know hat that is, yet) 46-4810,
clutch and brake - deck 8-7849
v-belt - deck 28-5250.
I guess I will have to remove the engine and see what the mechanism looks like. Any direction from the experts?? Thanks.
