bush hog z turn mower wireing diagram model #2355
im working on a bush hog mower model#m2355 can not get to turn over the key switch has power to it it has 3 relays can a relay be bad ?
Doesn't look like anyone came up with a diagram, I couldn't find one...
The circuit shouldn't be that difficult to trace. A test light will be your easiest tool to use. This is easiest done with a helper to sit on the seat and hold the switch to start.
Begin at the ignition switch and find the terminal that is hot with the switch in the start position. Follow the wire by color, see where it goes.
It could be a relay, but most likely it will be a switch out of adjustment, a wire pulled loose, pinched, chewed, etc.
Think of each item that will prevent cranking, seat switch, steering arm position, park brake, PTO switch, could be others. Just start checking for voltage getting through each component, see where you're getting it and where you're not.
