Troy Bilt Bronco keeps throwing deck belt
Why Worry
Hello all,
I have a Troy Bilt Bronco and it keeps throwing the deck belt. Any ideas of where to look for a solution?
I"m not going to be much help. I couldn"t keep belts on some of those Troybilts when I was doing warranty work on them.
Here"s what you can check: with the belt off, spin the spindles and idlers. Replace all that growl or rumble when spun because a bad bearing will cause extra heat on the belt. If any of the pulleys wobble, replace them.
Then install a new belt. When a belt comes off it usually damages some of the cords in it and then it is much more likely to jump again.
