John Deere LT 190 John Deere
The pulley on my transaxle fits over splined shaft.The spline inside the pulley is worn away.The spline on the shaft is somewhat rounded but I feel if I get a new pulley it will still fit and turned the shaft. Has any one had this problem and can I get by with just a new pulley.
Given the fact that a spline shaft/pulley setup by it's very nature is a tight/precision fit to prevent either from slipping(in place of a shaft key)any time you mix damaged/new parts the repair may/may not work or hold up in the long term due to torque & vibration,I've found this out the hard way over the yrs in commerical/ind installations,you have several options avail for repair.
1-buy a new oem pulley & take your chances.
2-measure diam of shaft(in/mm)then check local yellow pgs for a bearing/power transmission dealer,see what he has in stock that matches diam x bore needed in a set screw pulley,check with dealer if pulley can be returned/get a refund on same if not used,take pulley home & test fit,if tight to shaft dimple shaft for set screws & use BLUE loctite on set screws.
3-if orig pulley has a shoulder on top/bottom of same & bore is still tight enough to keep pulley true on shaft,drill a hole thru shoulder/shaft & use a small diam hardend socket(allen head)or star head screw & elastic nut thru same as a shear pin or drill/tap shoulder of pulley for small diam set screws dimple shaft & see if that works for you.
4-replace shaft(if possible) or replace transaxle.
I put the new pulley on had a little play. used JB weld and filled the pulley with it and then tack welded the pulley. Have cut several acreas of grass since doing this.
