Anonymous-0
I have a coleman powermatemaxa 5ooo er gen. engine 10hp Tecumseh model hm100 159272m dom 5 27 6 a this generator set up fo about 3 .5 years .I taken tank of clean wash it out and dryed replace on of valve new fuel lines filter new carb new plug clean coil and flywheel .it will crank up run fine it has clear filter when the fuel gets to half or less it start poping mishing then dies they wantbe mutch fuel in line .the only it willstart again is to take fuelline lose from carb hold line down fuel will fill line back up hook back carb it will crank up run fine .I have run with out fuel cap no change need help from you guys thanks
