ok got another prob with the old dixon, still something wrong with wiring but it'll fire up an run!! when i try to engage deck (it has an electric clutch) it kills the motor. there are 2 connectors on the bottom of the switch, i unhooked the connector that is going to a relay an now it turns on deck with killing motor. nothing else is going to the relay, 1 wire from the deck switch, other wire is looped back into the relay like a jumper? the wiring diagram i have shows a jumper but there is also another wire going to ignition switch. should i forget the relay since it works with it unhooked or will doing that burn up the deck clutch? (which i dont want to do)
