22 HP briggs wont turn
time2plow
I have a 22 HP Briggs Intek OHV motor on a craftsman rider.
When you turn the key it makes a half a revolution then kicks back and a coughing/squeaking noise comes out of the intake.
I thought starter was bad because when you put a boost on it it will start, but you might have to turn the key 10 times to get it to make a revolution. I thought the starter was dragging and replaced it with a new one.
Still does the same thing with the new starter and a new battery.
If I take the plug out of the right side there is no change. If I take the plug out of the left side she spins over nicely.
So what are your thoughts ? The kicker is when I do get it to turn over she will fire right up and run !!! I mowed with it for a 1/2 hour after I got it to turn over.
Shut it down, still the same, wont make a complete revolution to start, and kicks back. Tried it hot and cold there is no difference.
A valve problem on the left side? but she runs good when she runs, no smoke no noise.
I'm at a loss.
sorry for the long post but wanted to be thorough. thanks for your help
As cole said valves probably need checking or adjust on both cyl,each cyl is done seperately,with both plugs out bring cyl #1 piston to TDC of compression & check/set valve clearance,rotate flywheel till piston of #2 cyl at TDC & check/set clearance,set clearance to .005" on intake/exh valve of each cyl.
No you may have bigger trouble. When the engine messes around like that the next thing is compression release/ That is a REALY big job!!! Take the engine apart and you replace the little valve and the cam gear. The twins are a $700.5o engine so don't mess it up. Better if you take it to a shop or you must be REALLY brave. Neighbor did one last year and it just purrs now.
