Cub Cadet 1720 Transaxle issue?
tonygon
New User
I have a 1720 that will not go forward or reverse and rolls freely with or without the dump switch activated.
How do I know if I have a Transaxle issue or a Hydro pump issue.
if you jack up the rear of the tractor an make shore you vale is in the drive spot an start the mower an put the hydro in forward or reverse will it move did byou check the fluid leavel is full
