John Deere Sabre with starting problems solved.
Hello, I would like to thank all of you who responded to my posting. The problem was the Neutral Return Break Switch part number AM119978. As I mentioned in my earlier posting by holding the ignition switch and wiggle the pto lever I could get the tractor to finally start. I checked all of the safety interlock switches, then did a temporary jump for the ones that I knew were ok. I finally found that the Neutral Return Brake Switch was working intermittently. Thanks again, Jack
