huskee differential
Dayle
New User
does any one have a blow up pic of the way the differential is made. my manual justshow the whole item not broken down part by part. thanks Dayle :?: [/b]
If this is a late "Huskee" made by MTD get your transaxle model number from your mower parts list and do a search for that.
"MTD XXX-XXXX(x?) parts diagram". you should find several sites that have those parts. I use Google a lot to search for parts.
P.S. If yours is slipping, jerking, jumping out of gear, etc. You will be way ahead to just replace it. In a lot of cases the replacement has a different part number and is made a bit stouter.
