Got another 195
Case Nutty 1660
I always wanted a 195 with hyd lift, I was able to find this one, seems somewhat low houred and shows little use/wear, runs very well other than the throttle cable has no brake left in it and will have to be repaired/replaced, one question I have is about the drawbar, it has what looks to be factory tri-angle plate bolted to what my other has as a drawbar, something only the late ones had? hope you enjoy the pics, I will be polishing it up when I have time
cnt
cnt
What a big beast! I have a 223 Ingersol and love it for what it is. These Hi-drives are a hoot when you get used to them. What size tires are on the rear? Mine are 23-10.5-12. Jeffcat
They made a set of attachments for these as well, I have a snowblower/front blade/and 540 front mount PTO, they also had disc/cultivator and plow/sickle bar mower/ hyd drive tiller, they had more as well
cnt
Almost a weard car tire. I found a perfect used seat from a Yamaha that will fit my machine with only two holes to drill for the fit. OH..boo boo time , Mine is a 224 machine. Had it in the tractor parade at the farm fair a couple of weeks ago. In high range I can keep up no problem! Yea it is the orange one. That other monster has 620x70x42 shoes!! The lug bolt patern is 22 bolts! I want one for my back yard.
