Ron Galvin
New User
Looking for help with a manual or a solution for the pto clutch for my 111. I've had the friction plate resurfaced and it didn't fix the problem of not engaging. I re-engaged the clutch with the engine off and spun it manually. I would intermittently engage/disengage. I'm going to disassemble the clutch and was looking for someone with experience. Or, if someone had a manual clutch they would be interested in selling I could go that route as well. Thanks in advance. Ron
If the clutch is intermittent, the power supply is probably weak, or the switch is bad. Check where the clutch plugs into the wiring harness. Wire connectors do go bad.
