Poulan Leaf Blower Problem
on a poulan leaf Blower is it feasible to replace the Coil on these its a few yrs old BUT it has been So reliable I hAVte to Throw it away.. if this is poss its a polula Pro I hav eeliminated everything else it has Spark outside but i''m thinkin its not inside Cylinder/.. it is Blowing gas out the Muff, and I have taken it off to make sure not plugged.. HELP plz Larry
If you're blowing gas out the muffler the most likely cause of problem is carb needs a rebuild or replacement as eng is being flooded & plug gap is being shorted out by gas.Eng is designed to run on gas vapor not a liquid.
Joe is right. Too much gas in the cylinder will put out the spark in a 2 cycle engine.
You have fuel problems, but If its a Poulan Pro made within the last 5 years, I would dry the cylinder best I could and do a compression test. It may take several days for the cylinder to dry so you can get an accurate compression reading.
A flooded engine will always read higher than it normally would.
Install a compression gauge. Pull the rope until the pressure registered on the gauge stops rising. That is your max compression. If its not pretty close to 130psi., its probably time for a new blower.
