Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Poulan Leaf Blower Problem
motorcraftman
07-17-2014 15:00:18
on a poulan leaf Blower is it feasible to replace the Coil on these its a few yrs old BUT it has been So reliable I hAVte to Throw it away.. if this is poss its a polula Pro I hav eeliminated everything else it has Spark outside but i''m thinkin its not inside Cylinder/.. it is Blowing gas out the Muff, and I have taken it off to make sure not plugged.. HELP plz Larry
joe csuti
07-17-2014 17:30:07
 Re: Poulan Leaf Blower Problem in reply to motorcraftman, 07-17-2014 15:00:18
If you're blowing gas out the muffler the most likely cause of problem is carb needs a rebuild or replacement as eng is being flooded & plug gap is being shorted out by gas.Eng is designed to run on gas vapor not a liquid.
t.r.k.
07-17-2014 19:31:26
 Re: Poulan Leaf Blower Problem in reply to joe csuti, 07-17-2014 17:30:07
Joe is right. Too much gas in the cylinder will put out the spark in a 2 cycle engine. You have fuel problems, but If its a Poulan Pro made within the last 5 years, I would dry the cylinder best I could and do a compression test. It may take several days for the cylinder to dry so you can get an accurate compression reading. A flooded engine will always read higher than it normally would.
Install a compression gauge. Pull the rope until the pressure registered on the gauge stops rising. That is your max compression. If its not pretty close to 130psi., its probably time for a new blower.
Copyright © 1997-2015 Yesterday's Tractor Co.
