TractorLinks.com
starter/generator
fredmich
07-16-2014 08:36:04
My cub cadet 109 has quit charging. It starts good and the gage shows a slight discharge. I replaced the voltage reg. and polarized it per instructions but the gage still doesn"t show charge. Tried to check voltage with a cheap digital meter but it was all over the place. How do I check to see if the generator is putting out? Thanks...Fred
fredmich
07-17-2014 04:44:24
 Re: starter/generator in reply to fredmich, 07-16-2014 08:36:04
Thanks for the replies. I will try your suggestions tonight. The voltage reg. is after market but is the same one I put on my 149 and it works good. Thanks again....Fred
R Bedell
07-17-2014 03:31:01
fredmich:
A couple of things.
(A) When you replaced the V/R, did you replace with a CC part or aftermarket..??
(B) Is the V/R properly grounded..??
(C) Go to this link for the correct Wiring Diagram.... Diagram
Steve@Advance
07-16-2014 20:24:45
Check the wiring between the regulator and generator, and from the amp meter and the battery terminal on the regulator.
Don't think you have a generator problem. If it will start, it should charge.
http://www.ihcubcadet.com/forum/messages/106/152276.jpg
El Toro
07-16-2014 17:33:33
Your starter/generator may need new brushes if it has a lot of hours on it. I have a Delco S/G on my Wards tractor I bought new in 1971. I never had a charging problem, but it was a little noisy when running. I had new bearings and brushes installed at a local shop about 3 years ago. Nice and quiet now. Hal
PS: I have a cheap meter from Radio Shack no problems reading charging voltage across a battery.
jb9959
07-16-2014 13:38:03
Check the battery voltage with the engine off. Then, check the battery voltage with the engine running. If the reading is higher with the engine running, it"s charging..........
Juicybusa2
07-16-2014 09:34:38
Briefly ground the field terminal, if the gen is ok it will full charge. Listen for additional load on the motor when you ground it. This is a good indicator it's charging even if your gauge is inop or non existent. Just do this for a few seconds since there is no regulation of the current during the ground mode. If it charges, it's your wiring/regulator
