Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: CC 1320 engine mount bolts lost out
joe csuti
07-16-2014 03:28:46
You're probably better off taking eng to a machine shop,as you stated previously existing bolts are 5/16" so if existing threads stripped finding a right size drill bit/tap for 5/16" won't help you as there's probably not enough meat on id of hole to hold a thread,if you take eng to a machine shop they can probably install a heli coil or increase bolt hole/threads for a 3/8" bolt in addition to possibly getting broken bolt/extractor out,if they increase bolt size to 3/8",you'll probably have to open hole in chassis slightly for bolt.
As far as bolts extending into oil pan,if they did oil would run out of pan when a bolt removed,if a tapped blind hole when bolt(s)removed there is no oil loss,easy way to find out is take a thin blade screw drive,awl,ice pick or thin wire & stick into bolt hole & see how far it goes into hole before it stops.
Copyright © 1997-2015 Yesterday's Tractor Co.
