mrwood
New User
I need a coil for a 16 hp Tecumseh motor. Part # is 610906. They are the same from 10 hp to 16 hp. It is the old metal type. if anyone has one please let me know. I need it bad. Thanks for any help.
Do a google search for tecumseh 610906,some oem & aftermarket replacements listed,also try same search on ebay,you may find new/used oem coils listed.
If you have battery start you can install an auto type coil, then run battery voltage to the coil and to your points. Disconnect the old coil wire at your points. You will need a switch too. Hal
His engine has solid state ignition SSI no points. OEM SSI units a NLA and the used ones on E Bay start around $125.00 up to $200.00+ and are all 40 to 50 yrs old get a new aftermarket and be done for another 50 yrs.
GB in MN
