TractorLinks.com
used coil
mrwood
07-15-2014 14:38:41
I need a coil for a 16 hp Tecumseh motor. Part # is 610906. They are the same from 10 hp to 16 hp. It is the old metal type. if anyone has one please let me know. I need it bad. Thanks for any help.
El Toro
07-16-2014 04:30:03
 Re: used coil in reply to mrwood, 07-15-2014 14:38:41
If you have battery start you can install an auto type coil, then run battery voltage to the coil and to your points. Disconnect the old coil wire at your points. You will need a switch too. Hal
MNGB
07-16-2014 10:02:52
 Re: used coil in reply to El Toro, 07-16-2014 04:30:03
His engine has solid state ignition SSI no points. OEM SSI units a NLA and the used ones on E Bay start around $125.00 up to $200.00+ and are all 40 to 50 yrs old get a new aftermarket and be done for another 50 yrs.
GB in MN
MNGB
07-15-2014 20:11:48
Hi this is your best replacement, all new parts is basically a plug and play install and works.
http://overnight-solutions.com/index_files/Page391.htm
joe csuti
07-15-2014 19:33:21
Do a google search for tecumseh 610906,some oem & aftermarket replacements listed,also try same search on ebay,you may find new/used oem coils listed.
Bob
07-15-2014 16:17:15
Here's a link to some parts sources, and even a do-it-yourself replacement EI.
