Bruce frazier
wilson ind
this should show my home made tractor of sorts
bought at auction is cut down jeep axels and hyd
driven jeep transmission I plan to remove
transmission and put hyd motor on each axel. or just
sell the whole thing possibly less motor
Yep, you have got the right, old style air breather... I have the matching top and stuff!
I am not %100 sure what you are talking about for the throttle linkage that you need, but I do for sure have what you need! I'll take them off and get them ready to ship if you would like! Thanks, Bryce
picture 2 and 3 notice the rod from carb to govener lever with all the holes. Their is a spring which goes into one of the many holes on that rod. That is how governed speed is set, by which hole. the spring attaches to a lever having hole in each end and hole in center which serves as a piviot. Piovet hole fits on extended bolt which also holds one of the valve cover on.I need the spring and the lever with 3 holes and if you have it there is a chain from the bottom of the piviot to the cable throtte control. I can take a picture of the other engine if you need to see more of what I want. Good to get the air cleaner to fir correctly also. My phone is 812 699 0011 Just let me know the charges. Thanks Bill
