X720 John Deere
TP in IA
my X720 has 395 hrs it"s in the 4th season, anyway it has quit charging the battery ,I can put a charger on it and then mow for about 45Min then the mower deck quits (it engages electritly)) till i recharge the battery. thought mabe age of battery put in new battery same problem could it be the voltage reg? part # of regulator any thoughts THANKS
It could be the regulator, the stator, the magnets under the flywheel, or a problem in the wiring on the tractor.
Do you have a voltmeter?
