Page Two-Wheel Tracltor Don't know ...
Tony Wilson
New User
Don't know the correct name of the thing that holds the points to the tool bar. Sweep or plow point is bolted to a bar, the bar goes thru 'the thing' that clamps it to the tool bar. Some are designed for round bars and others for flat bars. I'll try to attach a picture. I need to locate some replacements of the same style /manufacture.
I call them a drawbar its where you drop a pin or bolt to secure the attachment to the tractor. I had StandardTwin and a Viking walk behind. The plow lever for adjusting the plow point tilt was bolted on using 2 bolts on the drawbar. It was also secured to the handlebars with 2 bolts to lift any attachment. Hal
PS: You had to remove the cultivator in order to install the plow. I made a frame so I could use the plow on my Wards tractor. I also had to
make a bracket for installing the plow on my sleeve hitch using one pin.
You're looking for "tool bar clamps". Finding them for a Paige might not be easy. If you have one example you may be able to get a local shop make you up a half dozen.
