JD 318 Question
Jonak
I have a JD 318 Yard tractor. The lights on the dash ,PTO switch and oil pressure light all do not work. Could the cause be the time delay module?? And Thank you in Advance:))
http://ctiowa.com/318power.jpg
If this is the correct wiring diagram,there is a 20a fuse in the pink wire after the ign switch that feeds that circuit.
Check for +12v at battery terminal of ign sw,depending on age of tractor most had a fuse/circuit breaker between battery terminal on starter sol & battery terminal(B)on ign sw,if fuse blown,breaker bad or connections loose/bad on either nothing on tractor will work.
