Lance Skene
I have here a '74ish Ford LGT tractor with what I believe is a JD 14hp K series that was swapped in by a PO, engine is all black but it had a JD air cleaner cover on it which recommends a JD part # for the filter... problem is there is no pto on it, and the Ford pto has a larger bolt pattern so those dont fit... output end of the crankshaft is also larger on the Fords, so the question is would this be the differance between a narrow block and wide block K series?
I have 6 of these old Ks here, 10 to 16hp, but only one is differant, and I'd like to find a pto for it but I need to know why its differant and what tractors might have the same block. tia
