325 jd trans. fluid
vilhelm
New User
Have a 325 jd lawn tractor, it stopped moving and the deck wont come up. serial number m00325b056313. what kind of fluid does this need?
Unless there's obvious leakage, likely it's NOT out of oil.
Check the drive belt system and verify that the transmission input shaft is tightly attached to the pulley.
If you DO need to add oil, the "spec" is for John Deere HyGard oil.
Basically "Universal Tractor Hydraulic and Transmission Oil".
Info source...
thanks for all replys. yes it was the drive belt and yes it was a pain to put on. thanks again vilhelm
