Thanks going out to t.r.k.!!!!
JD Seller
t.r.k.: You where spot on about where the deck drive belt adjustment was on the White/MTD LT13 mower. It was under the tunnel/floor panel. I adjusted it to move the deck forward a little more when it was in the disengaged position. I then had to adjust/bend the spindle brake straps that are under the floor boards.
The church lady is happy that she got to mow her yard before it rained this afternoon.
Thanks for your help!!!!!
You are welcome.
I have been working on mowers regularly for nearly 10 years now, full time for over 6 years.
