OK here I go on this one. Have a big beast of a Husqvqrna with a 22hp Briggs Twin V engine. While mowing the engine would sound almost as if it is constipated or it wants to burp. I asked a couple of very good repair guys who have big repair places and several experianced repair men. Also asked at the area parts house. Everyone comes up the same with :you need the little "O" rings in the carb:. One guy even gave me two little rings and said these should do it.
WELLLL.... $42.00 latter for the correct carb kit from Briggs and take her all apart and very carefully clean, ETC. etc. It ain,t gonna WORK!!! When you take the bowl off there is a little white tube assembly that has a tiny set of orifices in it. These little puppys are where these little rings should go. Well guess what, they were not nearly small enough. The rings that were on there are now little black crumbs. I now have a worthless carb!!!!!
Monday I am going to get on the phone to Briggs tech support and very nicely blow a fuse! The two little orifices should be press fit and or they should give you the little O rings. I will up date this after I call Briggs. By the way , the kit is made in the USA and has plenty of gaskets and sponge seals Etc Just nothing for those two little brass orifices. SCREEEEEAM!! Let you folks know later. Jeffcat
