Cub Cadet 3206 Hydro
agonair
I have a Cub Cadet 3206. Earlier this spring, I drained the hydro oil and put on a new filter.
Now, the damn thing leaks. It is not leaking at the filter nor plug, but around a gasket at the bottom. No leaking prior to the oil change. Very frustrating. Has leaked almost all of the new oil out. Had to put a drip pan under it.
Thoughts?
Where is oil leaking from-hydro case or differential case?
If its leaking from differential cover try tighting bolts for cover.
