Kohler pro no power
bdunegan
I have a craftsman gt 5000 with the Kohler pro 25hp twin motor. Problem is when you kick in electric Pto it pulls motor way down and acts like it wants to die, but then it picks up rpm and runs fine with plenty of power and cuts great even tall thick stuff. It don't matter if motor warm or cold. Any suggestions.
Might take a look at the governor linkage, make sure it's not bound up with dirt and grass. You can blow it clean of use some spray carb cleaner, no oil though.
If there is an idle mix adjustment, try backing it out 1/8 to 1/4 turn, may be just a little lean.
