TractorLinks.com
Re: Case 448 hydraulic problem
Kris Golden
05-27-2014 19:04:52
One side of your coupling is spinning on the shaft. That is causing the heat [friction] and it's not turning the pump as it should. Best of Luck!!
Tom Arnold
05-30-2014 06:00:20
 Re: Case 448 hydraulic problem in reply to Kris Golden, 05-27-2014 19:04:52
I think that Kris is right. Perhaps you forgot to install the key in one side or the other. Hopefully you did not ruin the new coupler half or the shaft itself.
Take it apart again. Clean up the shaft with emery paper (Plumber's Cloth). Use Blue Lok-Tite on the threads of the set screws. Make sure that you leave around 50 thou space between one coupler half and the spider. If the spider was damaged in any way, replace it now and save yourself the aggravation of having to do this all over again. The space is needed to allow for expansion as the parts warm up.
Let us know what you found when you dismantled it.
